DCR-HC90E SHUTTER PROBLEM
every time i switch on message reads "lens cover not fully open" does anyone have any ideas.
STEVE
Fri, 06 Feb 2009 16:50:00 +0000
Probably there is a little debris in the auto lens cover gears that is stopping it from opening.You could try slapping the camera with your hand or blow air on the lens in an attempt to dislodge the dirt.If that does not work and you want to try fixing things yourself you could disassemble the camera and then clean or replace the lens barrier module.After removing 13 screws from the outside of the camera and 2 on the inside the barrier can be pulled off the lens.It is part # 1-787-278-11.DCR HC90 service manual level 2 shows this part and camera disassembly steps.Here is a download link:http://www.eserviceinfo.com/index.php?what=search2&searchst . . . You must discharge the flash capacitor or you will get zapped.
Harvey
Sat, 07 Feb 2009 23:38:44 +0000
Spam Protection: * Answer of 2 + 10?
