I have had this unexplainable problem with my camera for some time. As I put the film that I have recorded into windows movie maker the film becomes pixelated and the colours are very bad. All the settings on my camera and the movie maker program are fine and I have 50% of my memory free. It has occured on two computers now yet there seems to be no porblem with the camera as the preview screen for the video I have recorded is fine. A friend of mine suggests that it could be the USB digitising going haywire. Please help me solve this problem I can't figure out a way to sort it! Thank you.
Mon, 17 Dec 2007 15:50:15 +0000
It's because of the USB connection. It is much lower quality compared to the DV quality of the Firewire connection. Take a look at these articles to help you get better quality:
Mon, 17 Dec 2007 18:28:41 +0000
I'm not sure it is though. I have always used my USB connection then suddenly it started doing the thing its doing now on 1 computer then for a couple of weeks it was fine on the second b4 it started doing it on that one 2.
Tue, 18 Dec 2007 16:27:54 +0000
Then you need to explain to us your video capturing/processing process so that we can discuss if any steps in there might be degrading your videos.
Wed, 19 Dec 2007 18:37:53 +0000
Try looking at this youtube video and see if you can spot any faults. MOVIE MAKER PROBLEM (YOUTUBERS YOUR MY LAST HOPE)
Sun, 23 Dec 2007 19:29:29 +0000
Embedded here for easy reference:
Mon, 24 Dec 2007 00:42:36 +0000
I noticed that when you capture, you use the "Best quality for playback on my computer (recommended)", which should be ok. But I can't make out the format specs in the "Setting details" section; that's the box on the lower left side. If you can type up the specs, that would help.
Also, in your video, you showed us how you captured the video, but you haven't showed us the process of saving the movie. That's the "Save Movie File..." under the "File" menu. How you save the movie file is equally important as capturing the file. Show us that process and the "Setting details" in the save movie process as well.
Mon, 24 Dec 2007 00:50:28 +0000
159 Users Online
